How to get coordinates in file name from rastertiler?
I'm looking for some help on what I am sure is a common problem hwoever being new to the software I'm not too sure what the correct terms are.
I am using the RasterTiler to split a large DEM into smaller tiles and write them to a new format. This is working fine but I would like to have the a coordinate of a corner of the raster written to the filename of the output. You've probably seen similar below, which is what I'm trying to achieve:
imageFor reference, this is what my workspace set up looks like:
imageThanks for your help getting me to understand this new software.
Best answer by nielsgerrits
You can use the BoundsExtractor to extract the x/y min/max from the tiles, then you can use these attributes in the filename. Sample workspace attached.
nielsgerrits
Forum|alt.badge.img+56
  • November 2, 2021
  • November 2, 2021
Thanks very much for your help, works like a charm.
