How to find charaters and replace it?
  • Mar 22, 2021 4:47 AM UTC
  • 90 views
hoa_le
I want to replace attributes from Unicode to without accent.
For example : Find âÂăĂđĐêÊôÔơƠưƯ --> Replace aAaAdDeEoOoOuU
Ăn >> An
Đô >> Do
Could you tell me how to replace it by python or other way?
Thank you
Best answer by caracadrian
Use StringPairReplacer with Replacement Pairs set to  â a Â A ă a Ă A đ d Đ D ê e Ê E ô o Ô O ơ o Ơ o ư u Ư U.
The pair are separated by space as following
key value key value
where key is the string you want to replace and  value is the replacement string.
caracadrian
Forum|alt.badge.img+23
  • Mar 22, 2021 5:30 AM UTC
key value key value
hoa_le
  • Mar 22, 2021 8:24 AM UTC
key value key value
Thank you so much @caracadrian​
  • Mar 22, 2021 11:21 AM UTC
There's a custom transformer on the FME Hub that does it for you:
https://hub.safe.com/publishers/jeroenstiers/transformers/stringcleaner
It's fully generic and does not need any settings.
