How to filter the last returned row
  • Jul 16, 2021 3:38 PM UTC
  • 5 replies
  • 199 views
oliver.morris
Forum|alt.badge.img+14
I am essentially looping through httpcaller results and need a way to pass a value from the last record returned in a loop, I dont know how many records will be returned. I was using the stats calc to get the max value but that is blocking the loop from running within the one workbench. Does anyone have any suggestions, thank you
Best answer by jdh
To use blocking transformers in a loop, you need to have a linked rather than embedded custom transformer. The loop input will also have to be published (really annoying, I generally call it LoopInputDoNotUse)
oliver.morris
  • Jul 16, 2021 3:41 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Jul 18, 2021 8:22 PM UTC
Use the sampler with it set to "Last N Features"
oliver.morris
  • Jul 19, 2021 10:50 AM UTC
thanks but unfortunately I get - Input Splitter (BranchingFactory): Transformer/Factory GetMembers_Sampler is blocking and cannot be used in a loop, but was found between... so the sampler is a blocking transformer for this loop as well.
jdh
Forum|alt.badge.img+41
  • Jul 19, 2021 7:24 PM UTC
oliver.morris
  • Jul 20, 2021 10:21 AM UTC
thanks, I went down this route as I dont think it is possible without blocking transformers.
