How To create Date Parameters
  • Nov 6, 2023 12:22 PM UTC
  • 486 views
Hello - I would like to use the attribute creator in FME to generate a StartDate and EndDate. The EndDate should calculate the last date of the previous month and the StartDate should generate the first date of the previous month. There is no data to refence so I would like to identify todays data and then use the logic to get the Start and EndDate.
The idea would be to use these dates as parameters when calling an API.
Does anyone have any suggestions on how I can implement this.
many thanks
Best answer by geomancer
Or this way, if you really want to use an AttributeManager / AttributeCreator:
geomancer
Forum|alt.badge.img+71
  • Nov 6, 2023 12:31 PM UTC
geomancer
  • Nov 6, 2023 12:47 PM UTC
thank you very much for your help :)
