How to create a line between two attributes at same table
  • June 16, 2023
  • 18 views
spiderman
Forum|alt.badge.img+7
Hello ,
i would like to create a line between two attributes that has coordinates at same table
This table has many points .
Id_1 | x1 |y1|id_2|x2|y2
x1 ,y1 relates to id_1
x2,y2 relates to id_2
Both of them are points. How could I create a line between id_1,id_2 and add text that include the value of id_1 and add text of value of id_2
FME 2021
Best answer by ctredinnick
You can use two Vertex Creators in series to create the line. The first one in mode Replace With Point, on x1,y1. The second one in mode Add Point, on x2,y2
ctredinnick
Forum|alt.badge.img+19
  • June 17, 2023
