How to convert multi line strings in cell into one line at the same cell ?
  • September 1, 2023
  • 300 views
spiderman
Forum|alt.badge.img+7
Hello ,
I have many cells that include the strings in two lines
at specific cell includes
building CR LF
one side
i want to change the two lines into one line
to be
building one side in one line at the same cell
CR LF : created from Fme ,I am not sure what does it mean ?
fme 2021
Best answer by nielsgerrits
You can do this using a StringReplacer. Simply open the Text To Replace texteditor, hit Enter on your keyboard and choose for a Space for the Replacement text.
CR LF refers to Carriage Return and Line Feed. They are used to note the termination of a line.
As an alternative you can use regex to do this, you need something like
(\r\n)
nielsgerrits
Forum|alt.badge.img+56
  • September 1, 2023
(\r\n)
