Hello ,
How to convert file geodatabase to arcsde ?
thanks in advance
FME 2021
SDE is basically a GDB on a database.
You need an existing SDE environment setup (And connection file). It's then just a case of setting up your SDE writer just as you would a GDB writer
17 votes
15 votes
12 votes
10 votes
8 votes
7 votes
5 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
