How to combine two attributes ( Latitude and Longitude ) to One attribute ( Point)
  • May 5, 2021 4:35 AM UTC
  • 100 views
How to derive a coordinate from Geocoder transformer (latitude and longitude) attributes
Best answer by DanAtSafe
In that case, follow the Geocoder with a VertexCreator to create the point geometry from those attributes.
DanAtSafe
Forum|alt.badge.img+23
  • May 5, 2021 5:53 AM UTC
Hi @naranawinkumar​ The Geocoder already returns a point (geometry) as well as the coordinate in the  ‘_latitude’ and ‘_longitude’ attributes. Is your Geocoder returning something other than a point?
Hi @danatsafe​ , The Geocoder is not returning the coordinate. It only returns the ‘_latitude’ and ‘_longitude’ attributes.
Output:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/geocoder.htm#
Thank you!
DanAtSafe
  • May 5, 2021 5:46 PM UTC
Thank you @danatsafe​
