How to assign a value to a new field when if condition is met
  • September 10, 2021
  • 304 views
messagemauri
Using FME Desktop 2021. I have an existing field LicenseNumber with null values and with numeric values. I want to create a new field called License_Values into a table if the following conditions are met:
Condition 1
If LicenseNumber is null
Then assign null values to License_Values
Condition 2
If LicenseNumber is not null (it has values)
Then assign 123 to License_Values
I tried AttributeCreator with a Condition value but it does not work at all. All
it does is assign 123 to every record in the new field called License_Value (Condition 2) and it does not write the null values to License_Value (Condition 1) . My final objective is to have the new field with null values and 123 as long as the conditions are met.
image1Condition
Thank you, much appreciated.
gazza
I suspect that LicenseNumber is not NULL but one of the other states, Empty or Missing. Put everything through an AttributeFilter and see what ports they come out of.
messagemauri
@Gary Nicholson​ Thank you. Yes, I added the AttributeFilter and put everything through (Null, Empty, Missing), I then connected it to an Attribute Creator with all the conditions (Null, Empty, Missing) and it works.
Thanks Gazza
caracadrian
Forum|alt.badge.img+23
  • September 14, 2021
Alternatively you can use the Attribute Has a Value clause in the condition to bypass the NULL, EMPTY, MISSING state of the attribute.
