How to add to existing value
  • Sep 8, 2023 6:29 PM UTC
  • 216 views
Currently I have few AttributeCreator to do the following:
  • Insert numbers into table if no matches found (Attribute Value=INSERT)
  • Replace number into table if matches found (Attribute Value=UPSERT)
However there's a need to add numbers to existing values. Do not see any APPEND or ADD attribute value from the dropdown.
Any help would be appreciated!
Forum|alt.badge.img+63
In the editor you can simply reference the original value of the attribute and then add something to it.
