How to add a private parameter "Date" to a reader source
  • Nov 13, 2020 8:56 PM UTC
  • 108 views
Trying to add a date parameter to a reader's source URL in the mm/dd/yyyy format for today's date
bwn
Forum|alt.badge.img+26
  • Nov 14, 2020 9:52 AM UTC
Try:
@DateTimeFormat($(MyDateParameter),%m/%d/%Y)
See FME Date/Time Functions help for further reference:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/!Transformer_Parameters/Date-Time-Functions.htm
bwn
  • Nov 15, 2020 11:55 PM UTC
Try:
Just re-read the bit about this being today's date.   You strictly speaking don't need a Parameter to do this for the Reader Source string.   The above formula could be rewritten as:
@DateTimeFormat(@DateTimeNow,%m/%d/%Y)
So the Source URL can be written to be evaluated as:
http://mywebdatasource.com/date@DateTimeFormat(@DateTimeNow,%m/%d/%Y)
Or whatever URL string parsing is required.
  • Nov 16, 2020 8:43 AM UTC
An alternative is to replace the reader with a FeatureReader transformer. You can then start the workspace with a Creator and follow up with a DateTimeStamper (and DateTimeConverter, if necessary) before passing it on to the FeatureReader as a part of the URL.
