How do I set up HTTPCaller to get a token using curl
  • August 23, 2023
  • 95 views
here's the curl:
curl --request POST \\
   --url https://api.assetpanda.com/v3/session/token \\
   --header 'accept: application/json' \\
   --header 'content-type: application/json' \\
   --data '
 "email": "username@company.com",
 "password": "pASSWORD123"
Best answer by daveatsafe
Hi @eric.collins​,
I think the following settings should work:
Screen Shot 2023-08-23 at 3.41.44 PMYou can use a JSONFlattener to extract the authorization info from the response, if needed.
daveatsafe
Forum|alt.badge.img+19
  • August 23, 2023
Hi @eric.collins​,
