How do I replace a single quote with 2 x single quotes when passing parameters to a stored procedure?
  • Oct 6, 2020 4:30 PM UTC
  • 349 views
I have the requirement to grab some data from a SQL Server Database and row by row (so granular error logging can be performed) use a stored procedure to insert that data into another table. However, when calling the stored procedure to perform the insert I need to escape the single quote character (') by replacing it with 2 x single quotes.
I have tried using the StringReplacer transformer but when it comes to using the re-formatted string as the input for the stored procedure it does not seem to pull through at all, the SQLExecutor Transformer loops through all the records correctly but when calling:
EXECUTE [dbo].[InsertData] @Value(contact_number), '@Value(title)', '@Value(first_name)', '@Value(middle_names)', '@Value(surname)', '@Value(address_1)', '@Value(address_2)', '@Value(address_3)', '@Value(address_4)', '@Value(town)', '@Value(county)', '@Value(postcode)', '@Value(country)', '@Value(email_address)', '@Value(telephone_number)', '@Value(mobile_number)'
nothing is entered into the table.
However, this does work when directly connecting to the SQLExecutor Transformer, it loops through and inserts the records, but then it errors when it encounters a single quote.
How can I achieve this please?
Thanks
Gary
  • Oct 6, 2020 4:52 PM UTC
This is unfortunately a fairly common issue as the SQLExecutor does not support bind variable (vote here!)
Oracle has a pretty good workaround, but it's not available on SQL Server.
However, if your strings may contain single quotes, but no double quotes, you can do the following:
FME_SQL_DELIMITER ;
SET QUOTED_IDENTIFIER OFF;
EXECUTE [dbo].[InsertData] @Value(contact_number), "@Value(title)", "@Value(first_name)", "@Value(middle_names)", "@Value(surname)", "@Value(address_1)", "@Value(address_2)", "@Value(address_3)", "@Value(address_4)", "@Value(town)", "@Value(county)", "@Value(postcode)", "@Value(country)", "@Value(email_address)", "@Value(telephone_number)", "@Value(mobile_number)";
This way you can use double quotes to pass the strings into the InsertData function, and the single quotes contained in any of the attributes are correctly parsed as such.
  • Oct 7, 2020 8:02 AM UTC
Thanks David, this reduces the number of records in the log file we need to go through for records that have not been imported
