How can I send batches , for example, 5 rows from the database (SQL non-Spatil) and send to a JSONTemplater and repeat this process?
  • Mar 15, 2023 6:01 PM UTC
  • 129 views
yamadar
I am new to the FME desktop.
I am reading data, for example, 10 rows from my database (SQL non-spatial) transforming it to JsonTemplater and sending it via HTTPCaller. It is working fine.
Therefore, there is a constraint to sending only batches of 100 rows per JSON file.
I have already tried the decelerator but the decelerator only delays the rows.
Could somebody help me?
Thanks
Raphael Yamada
itsmatt
Forum|alt.badge.img+48
  • Mar 16, 2023 1:38 PM UTC
Check out the GroupBy option in the JSON templator
imageIf you can make sure each 'batch' of features have an attribute with a shared group id/name then the JSONTempator will process the features coming in in batches.
You'll also need one root feature per batch/group as well (this should also share the same group id as the batch of users
yamadar
  • Mar 17, 2023 10:17 PM UTC
Thanks,
You gave me a great idea to separate into groups and count. I used the transformer "GroupCounter" and it worked. Thanks for helping me.
itsmatt
  • Mar 20, 2023 7:09 AM UTC
Thanks,
Excellent solution, nice
