how can i run my workbench with batch file ?
  • May 4, 2022 4:46 PM UTC
  • 719 views
charlesdollat
Forum|alt.badge.img+3
hello i would like to RUN my workbench with a batch file, so i copied the first line of the log but when i try it, it just launch FME with the workbench but he doesn't run it. how could i do that ?
thanks
charles.
Best answer by rahulsharma
Hi @charlesdollat​
In the log window, you should see from Line 5 to Line 10  If you copy and paste those lines, ensure that it is in a single line and save it into a bat file it should work.
Feature Caching is ON
The workspace may run slower because features are being recorded on all output ports.
    Command line to run this workspace:
        "C:\Program Files\FME_2021.2\fme.exe" C:\FMEData2020\Workspaces\DesktopAdvanced\Attributes-Ex4-Complete-Advanced.fmw
          --SourceDataset_MITAB_3 "C:\FMEData2020\Data\Parks\Parks.tab"
          --DestDataset_FILEGDB_3 "C:\FMEData2020\Output\Parks.gdb"
          --FME_LAUNCH_VIEWER_APP "YES"
The above taken from our tutorial workspace can be run from the command line using following command
"C:\Program Files\FME_2021.2\fme.exe" C:\FMEData2020\Workspaces\DesktopAdvanced\Attributes-Ex4-Complete-Advanced.fmw --SourceDataset_MITAB_3 "C:\FMEData2020\Data\Parks\Parks.tab" --DestDataset_FILEGDB_3 "C:\FMEData2020\Output\Parks.gdb"
If you need more help please refer to the following
Article -- Batch processing from the command line
Working with command files
rahulsharma
Forum|alt.badge.img+12
  • May 4, 2022 5:51 PM UTC
Hi @charlesdollat​
charlesdollat
  • May 5, 2022 9:11 AM UTC
Hi @charlesdollat​
thanks !  it's working
