How can I properly read attributes of a KML and its values ?
  • November 24, 2020
  • 286 views
mapster
Inserting a KMl into FME desktop results in a schema-less reader. Which steps do I have to take to convert its attribute (values) to e.g. shapefile or fgdb?
Best answer by davtorgh
Hi @mapster​ ,
you can view the attributes (names and values) in the Data Inspector feature information windows and use an AttributeExposer to expose the attributes you need in your workspace. You can then manipulate them and write output to whatever format you want.
Hope that helps!
davtorgh
Forum|alt.badge.img+11
  • November 24, 2020
Hi @mapster​ ,
Hope that helps!
mapster
  • November 24, 2020
Ah! That helps! Thank you :)
