How can I convert with "AttributeCraetor". For example, I want 123,34 to 123.34. commas to dot thanks
  • Apr 29, 2021 7:39 AM UTC
  • 56 views
Best answer by caracadrian
If you want to replace commas to dots in AttributeCreator use the ReplaceString function:
@ReplaceString(@Value(attribute),",",.)
Don't forget to enclose your comma in double quotes.
  • Apr 29, 2021 7:53 AM UTC
The easiest would be to use the StringReplacer.
caracadrian
Forum|alt.badge.img+23
  • Apr 29, 2021 8:18 AM UTC
  • Apr 29, 2021 8:27 AM UTC
thank you. I've been using FME for 2 weeks. It worked .
