Hi, What would be the best solution for splitting a pointcloud into smaller parts based on number of points? Eg. One new output-file for Every 1000 points.
  • Apr 1, 2021 6:52 PM UTC
  • 6 replies
  • 164 views
I can’t use the pointcloudcoercer and then group on ”count” since it still need to be in pointcloud- format when writing to Xyz-fileformat. Do I really need to first write to xyz and then bring it back in to split it up?
Thanks
Best answer by jdh
Have you looked at the PointCloudDensityTiler on FME Hub?
https://hub.safe.com/publishers/safe-lab/transformers/pointclouddensitytiler
siennaatsafe
Forum|alt.badge.img+12
Hi @abbe11​
I'd recommend using the PointCloundExpressionEvaluator to create a new component, the expression should be something like @index()/1000. Then, use a PointCloudSplitter to split by that component.
I've attached some images and a workspace as an example. 2021-04-01_15-56-302021-04-01_15-57-23
jdh
Forum|alt.badge.img+41
  • Apr 5, 2021 5:01 PM UTC
  • Apr 6, 2021 5:32 AM UTC
Thanks @jdh​ , that almost does what I am after. However, Is it also possible to get a "tile-id" to achieve the final split/fanout on?
  • Apr 6, 2021 5:44 AM UTC
Hi @abbe11​
Thanks @siennaatsafe​, this works well. The newly created component "t" isn't exposed as an component, right? (It is still possible to use it in pointcloudsplitter though, but not as a component in "split by"- drop down.)
jdh
  • Apr 6, 2021 6:08 PM UTC
You could just add a Counter to get an id for the fanout.
siennaatsafe
Hi @abbe11​ ,
That's right, it won't count as an exposed component, but can be written in the pointcloudsplitter (however not selected by the dropdown).
