Hi, I get a few points out of an oracle database with an sql creator. Next I need to display these Points but not as "normal" point but as a symbol out of an Font. How can I do this?
orkng
FME Desktop 2022.2.3
Best answer by david_r
david_r wrote:
You'll have to use the LabelPointReplacer before the PDFStyler. Example:
imageResult:
You won't see the result in the FME Data Inspector, as it renders the text using its own font without considering the font choice set in the PDFStyler. You'll have to write the label to a PDF file to see the results.
nielsgerrits
Forum|alt.badge.img+56
You can do this using a Labeller or LabelPointReplacer.
orkng
  • April 27, 2023
Any example how to setup? E.g. use windings Font "0x40" to replace the Point (and than export this to pdf?)
Labeller
  • April 27, 2023
For PDF output you should add the PDFStyler and specify the font (e.g. Wingdings) there.
Alternatively, you can use the TextStroker to convert the symbol into vectors.
orkng
  • April 27, 2023
can't find an option in the pdfStyler where I can replace the point as a font icon? Even I find no examples online. ... anyone have a example?
  • April 27, 2023
imageResult:
orkng
  • April 27, 2023
imageResult:
Something I do still wrong?
PDFStylerimage
Result:
  • April 27, 2023
imageResult:
orkng
  • April 27, 2023
imageResult:
Thx a lot!
  • April 27, 2023
imageResult:
I forgot to say, if you simply need to visualize the label using the correct font for quality control, you could use the TextStroker before visualizing the result.
orkng
  • April 27, 2023
imageResult:
This was the last step! Thank you very much!
