Hello, I'm new to FME desktop, I want to ask if there is a way to add object mapping so i get the value of a key?
  • Mar 13, 2023 9:54 AM UTC
  • 52 views
I am making an HTTPCaller request that in return outputs key, I need to make another HTTPCaller request with the value of the returned key (e.g, if returned key = "Yes" value is 15225 | if returned key = "Male" it's corresponding value is 15222)
is there a way to store an object on FME desktop to be used like _instance ??
I think it might be done using JsonValueMapper transformer
Forum|alt.badge.img+54
  • Mar 13, 2023 10:15 AM UTC
Assuming you have extracted the key from the json response from your first HTTPCaller you can use an AttributeValueMapper to map to a new value stored in an attribute which can then be used in the following http request
@ebygomm​
Thank you so much for the solution, I will be using it.
but seems I have to use the JSONFlattener so to rearrange the JSON because my returned JSON is array of objects and I wanted it to be object of keyValue: anotherKeyValue if it makes sense
current object structure
[{"Question": Question_Value, "QuestionId": QuestionId_Value, "", ..},
{"Question": Question_Value, "QuestionId": QuestionId_Value, "", ..}]
desired object structure
{Question_Value: QuestionId_Value,
Question_Value: QuestionId_Value,..}
