Having a problem using featurereader to read a downloaded zip file (using HTTPCaller). The zip file contains a spatial dataset.
  • Apr 6, 2021 8:25 AM UTC
  • 14 replies
  • 340 views
Hey folks,
As per the question itself, I'm really struggling with (what I assumed) would be a straightforward task. (Straightforward in that I cannabalised an older workbench which works just fine and simply switched up the HTTPCaller url and featurereader parameters and thought it would work.)
The way (I assume) it works is that the HTTPCaller calls the zip file from an online repository, then the featurereader reads the contained shapefile and I can then go on to do other processing tasks. However, the workbench is failing at the featurereader stage. The logfile has an error message that says:
Unable to open shape file `C:\\Users\\[USER]\\AppData\\Local\\Temp\\FME_TempFileStore_161769518366_3180\\dsR_1_161769518367_3180\\DBCALegislatedLandandWaters.zip_161769518367_3180\\DBCALegislatedLandandWaters.shp' for read.
I have no idea what the issue is, I've purged temporary files, screwed around with the parameters of the feature reader but am unable to get beyond this point. Does anyone have any suggestions or encountered anything similar?
Happy to upload the workbench if required.
Cheers,
Marty
Best answer by hkingsbury
Sure thing Kailin, and thanks again, file attached. And in case you also need it, the download link: https://maps.slip.wa.gov.au/datadownloads/SLIP_Public_Services/Property_and_Planning/DBCA_LegislatedLandsandWatersDBCA_011/DBCA_LegislatedLandsandWatersDBCA_011.zip
You need to create an account to download, but it's free. I've also factored that in as part of the workbench - using my credientials to authenticate.
See below, you need to specify the path to read your shapefile like
@Value(zip_loc)/*.shp
Screenshot 2021-04-09 095943
nielsgerrits
Forum|alt.badge.img+67
Just to be sure, you downloaded all the files? Not only the .shp but also the .dbf and the .shx? I think those are the bare minimum you need to read the .shp.
  • Apr 6, 2021 9:29 AM UTC
Good question. I'd have to say I'm not sure but I think so. The zip file (when I download it manually) contains all component shapefile parts, and I use the same url for the HTTP Caller, but I'm not sure how to check that within FME.
nielsgerrits
Do you unzip the file or read directly from zip?
hkingsbury
Forum|alt.badge.img+73
  • Apr 6, 2021 10:03 PM UTC
You can pass the url of the zip file straight into a SHP reader/featurereader and it will download it and treat it as if it was reading a zipped SHP directly off the machine
  • Apr 7, 2021 1:26 AM UTC
Hey thanks hkingsbury. Tried that, however within the featurereader, the output always goes to the 'rejected' section, no matter what I do.
  • Apr 7, 2021 1:28 AM UTC
I read directly from the zip (using the response_file_path parameter) but in every case, no matter what settings I play with, the output always goes to the 'rejected' section of the FeatureReader.
Cheers Nielsgerrits.
kailinatsafe
Forum|alt.badge.img+24
Hello @martyrocks​ , would you be able to share your data? Here to help, Kailin
  • Apr 8, 2021 1:41 AM UTC
hkingsbury
  • Apr 8, 2021 10:00 PM UTC
  • Apr 9, 2021 12:15 AM UTC
Hey thanks hkingsbury, that works a treat!
I'd love to be able to pull directly from the URL rather than download and then read, that seems to be the main stumbling block for me in this case!
Regardless, thanks very much for your help and input, its very much appreciated!
Marty
hkingsbury
  • Apr 9, 2021 3:12 AM UTC
I do note that WFS serivces are avaliable, however they were pretty slow and kept failing on me. You could just read this straight into the workbench using the WFS reader
https://catalogue.data.wa.gov.au/dataset/dbca-legislated-lands-and-waters
  • Apr 13, 2021 1:31 AM UTC
Hey thanks again hkingsbury. May be a silly question - where does the 'zip_loc' parameter come from?
hkingsbury
  • Apr 13, 2021 7:46 PM UTC
@martyrocks​  you can add attributes to a creator by right clicking on the blue part of the output port and selecting "Add Attribute"
Screenshot 2021-04-14 074207
  • Apr 14, 2021 7:17 AM UTC
Ah nice one. Thanks again hkingsbury!
