Has anyone successfully obtained a token from ArcGIS Server (10.9) using HTTP Caller?
  • Jan 9, 2023 5:26 PM UTC
  • 609 views
agelfert
Forum|alt.badge.img+8
Trying to automate some ArcGIS Server monitoring and am struggling to get a token using HTTP Caller. I think there may be a bug on the ESRI end (surprise!). But before I post on their forum, I wanted to pin the FME world.
I'm making a POST to here:
myserver.domain:6443/arcgis/admin/generateToken
which is the same place I go for manually obtaining a token. As query parameters I have:
client : requestip
f : json
 as Headers:
Content-type : application/x-www-form-urlencoded
 Accept : text/plain
I have tried both putting username/password in Body and Query. Neither works. If I grab a token manually and pass it in the HTTP Caller as parameter, I have no trouble making a connection to the same URL.
Has anyone gotten this to work, or has a clue where I'm going off course? Thanks
debbiatsafe
Forum|alt.badge.img+24
Hello @agelfert​
I was able to obtain a token from an ArcGIS Server instance using the following settings in the HTTPCaller:
HTTPCaller settings to obtain token from ArcGIS ServerI specified the required request parameters (username, password, client, f, etc.) in the Upload Body and set the body Content Type as 'URL Encoded'. The format of request parameter is <requestKey>=<requestValue> (eg. username=test123) with an & symbol delimiting each request parameter. I did not have to use additional query strings or headers. I hope this information helps.
Upload Body format to obtain token from ArcGIS Server
agelfert
  • Jan 9, 2023 9:27 PM UTC
Just learned that if I use this:
all parameters need to go in the body. I still had 'client' and 'f ' in the query. Good to know.
Related thread.
https://community.esri.com/t5/arcgis-enterprise-questions/obtaining-arcgis-server-token-programmatically/td-p/1246547/jump-to/first-unread-message
agelfert
  • Jan 10, 2023 3:12 PM UTC
Hello @agelfert​
Thanks, @debbiatsafe​  I will check it out. My premature exuberance yesterday quickly evaporated when i realized I was no longer getting an error but still not getting my token. Haha.
