Handling NaN values
  • May 9, 2023 10:00 AM UTC
  • 400 views
I have a workspace that can sometimes generate some NaN-valued Real64 data types (from the surface draper specifically).
I'm really struggling with how to handle these. FME seems very inconsistent with how I can test them. I would like to test for them and terminate the workspace if they are found.
So far I have tried:
  • Attribute Validator by type (numeric)
  • Attribute Validator by 'Has a Value'
  • Attribute Validator by 'Not Null'
  • Tester by all of the above
The only thing I was able to get to work is a tester using
@abs(@Value(MyMaybeNANAttribute)) < 0.00000000000000000000001
where I just used the number on the right as an arbitrarily small floating point number. This evaluates to True for my nan values, so I can filter them out. However, this is not a good workaround because I can have valid zero value in some cases.
I have searched the forums and the articles and I have not had a good explanation of how NaNs are handled in FME. Is there a way I can catch these with a data validator or a tester?
daveatsafe
Forum|alt.badge.img+24
  • May 9, 2023 8:13 PM UTC
Hi @mlindsvo​,
A NaN value will fail any numeric test, so use a Tester to see if the attribute in question equals itself, in Numeric mode. Only the NaN values will fail.
