Google Sheet Columns not reading in Reader
  • Oct 22, 2019 2:43 PM UTC
  • 61 views
blackheart
i'm getting probelm i google sheet .. everything is OKay but when i connect the sheet some columns are coming and some are not showing in transfrmr pleae anyone can help me out
itsmatt
Forum|alt.badge.img+48
  • Oct 23, 2019 12:37 PM UTC
If the Reader was added and new columns were added after the Reader was added you might want to try ReAdding the reader.
What might be happening (and is a fairly common problem) is that when you first add a Reader FME will scan the data and create a schema based on that data/those columns. If you then add new columns but don't Re-add the reader (or update the feature type) then FME doesn't know about the new columns.
Try deleting and Re-adding the Google Sheets Reader.
Another possible issue is that you have defined the Reader based on a 'Named Range' where the Named Range contains some, but not all, of the columns. Check that if reading a Named Range that the columns which are missing are contained in that range.
