Generate Hexagonal Grid
  • Apr 10, 2023 4:04 PM UTC
  • 1038 views
philippeb
Forum|alt.badge.img+23
Hi !
Any idea how to create a 2D grid with hexagons instead of squares?
I would like to reproduce this tool : https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/generatetesellation.htm
I tried HexBinner transformer but it works with points. So when I try with a grid of points I created, there is some holes in my grid, as you can see...
Thank you !
dustin
Forum|alt.badge.img+36
  • Apr 10, 2023 4:37 PM UTC
There is likely a way to do this natively in FME, but it will probably take a combination of transformers. When I have a task like this, I will usually lean toward creating a temporary GDB using TempPathNameCreator, run the ESRI tool via PythonCaller on the temp GDB, then read the data back in using a FeatureReader.
philippeb
  • Apr 10, 2023 5:07 PM UTC
I just found out the HexagonSampler. I modify the user parameter value and bingo ! :)
https://hub.safe.com/publishers/larry/transformers/hexagonsampler
caracadrian
  • Apr 10, 2023 6:54 PM UTC
Nice tip for HexagonSampler.
This reminds me that hexagons are the bestagons 😁
