Generate a Grid
  • Oct 7, 2016 5:01 PM UTC
  • 211 views
danilo_fme
Forum|alt.badge.img+58
Hello User`s.
As you can see below, i have two Source Datas ( Grids polygons ). The source BLOCOS_BS ( blue polygons )has 3 polygons and i need to generate 3 outputs with GRIDS from another source data BLOCOS_TOTAL ( red polygons ).
For example to Polygon 1, the output data will be all polygons reds together this polygon 1: One shape file with all poligons
For example to Polygon 2: Generate another shapefile with all polygons belows:
Thanks in Advance,
Best answer by takashi
Hi @danilo_inovacao, create three copies for every red polygons with the Cloner, and write them into three Shapefile files with feature type fanout based on the copy number - 0,1,2. For the blue polygons, add sequential number - 0,1,2 (the same name attribute as the copy number attribute for the red polygons) with the Counter, and write them into the same writer feature type as the red polygons.
  • Oct 8, 2016 12:50 AM UTC
danilo_fme
  • Oct 10, 2016 8:38 PM UTC
Hi @takashi, thanks your help. I writed a Geodatabase and Works with me :)
Thankssssss
