from 1 excel template to multiple sheets
  • Nov 9, 2020 6:35 PM UTC
  • 185 views
alc33
Forum|alt.badge.img+14
Hi!
I would like to duplicate my template (excel) to create multiple sheets based on an attribute on my datas. For example, when my attribute = sheetA, all the datas concerned go to named ranges on the sheetA.
At the end I have one file with multiple sheets.
But I saw this sentence :
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/xlsx/XLSX_writer.htm
"Named ranges that exist on the template sheet are not duplicated."
So I thought to use feature writer to write each sheet independantly with the same name sheet and then use feature reader + writer to group all the files in one and rename the sheet with the good value.
This solution is a problem for me because I would like to delete the intermediates files automatically but FME can't do that.
I'm not used to write on excel so it became a little complicated for me.
Can you help me?
Thanks!
milo89
Forum|alt.badge.img+26
  • Dec 7, 2020 11:23 PM UTC
Hi @alc33​,
I would recommend having a look at Feature Type Fanout using the attribute which contains the sheet ID.
Hope this helps.
