FORMATTING DATES I can get this to work: @DateTimeFormat(20210127,%Y) = 2021 What I want to do is use the value of an attribute as the date input, like this: @DateTimeFormat(@Value(Date_Installed),%Y)
  • Feb 5, 2021 2:51 PM UTC
  • 79 views
Forum|alt.badge.img+54
  • Feb 5, 2021 2:56 PM UTC
Is the date held in Date_Installed in an FME Format? The syntax that you've posted should work if that's the case.
  • Feb 5, 2021 3:09 PM UTC
Thanks for confirming that it should work ... that helped me fix the problem.
