For loop in FME
  • Jul 11, 2018 11:43 AM UTC
  • 183 views
raaaju1990
Forum|alt.badge.img+11
I'm accessing an API using FME and trying to fetch records by passing certain ids as a parameter to the API . For example the API is,
https://developers.onemap.sg/commonapi/elastic/omsearch?searchVal=1&returnGeom;=Y&getAddrDetails;=Y
In the above API, I need to keep on increment the value of searchVal=1 from 1 to 100 and then pass each to httpcaller to return the response.
I'm able to do this using python caller and get the response using for loop concept. But, I want to do this without python and use any other transformers which does the trick for me.
Any guidance would be appreciated.
Thanks!
  • Jul 11, 2018 11:49 AM UTC
oscard
Forum|alt.badge.img+23
  • Jul 11, 2018 11:52 AM UTC
I would use a Creator with 100 copies.
With AttributeManager I would create a new attribute: searchval = (@Value(_creation_instance) + 1)
The request would be like this:
https://developers.onemap.sg/commonapi/elastic/omsearch?searchVal=@Value(searchval)&returnGeom;=Y?tAddrDetails=Y
