FME Server - How to upload a folder (unzipped) with shapefiles or gpx data in it
  • Jul 11, 2022 11:26 PM UTC
  • 92 views
epro_admin
Forum|alt.badge.img+7
Hi there,
Thanks in advance for your help. It's my first time using FME server and setting up an app. I want the end user to be able to upload a folder full of shapefiles or gpx files.
In Desktop, I have the parameters set up so the user can upload folders and the subfolders within it. I can't find this option in server. I see I can upload one file at a time, but that's not what I want. Can anyone point me in the right direction?
I want to capture all this info in the folder structure:
OperationName>Fieldworkername1>All the gpx and shapefiles
OperationName>Fieldworkername2>All the gpx and shapefiles
OperationName>Fieldworkername3>All the gpx and shapefiles
Best answer by epro_admin
@keziaatsafe​ Thanks for your reply. I ended up chatting with support about this. I hadn't activated my parameters correctly in Desktop before I loaded it into Cloud. The plan is to load it in as a zipped folder.
keziaatsafe
Forum|alt.badge.img+8
Hi @epro_admin​ ,
From my understanding, it is not possible via Temporary Uploads, however you could do so via the Resources tab > Data folder and have the user create folders to place the gpx and shapefiles into.
ResourcesUploadHope this helps, let me know how it goes for you.
-Kezia
epro_admin
  • Jul 14, 2022 9:28 PM UTC
