FME Server fails without errors in log
  • Nov 14, 2023 2:38 PM UTC
  • 251 views
mathiku
Forum|alt.badge.img+8
This is an FME Server that has recently begun to cause problems. One of the scheduled jobs fails but there is no information in the log.
Any leads on how to proceed and solve this problem?
FME Server 2022.2
Build 22765 - win64FME Server failure without log
Best answer by itsmatt
It could be that this job is crashing - often a crash wont be reported in the log. If a job crashes then FME Server will try and resubmit it a few times before giving up.
To confirm this you can look in the fmeprocessmonitorengine.log (logs>engine>current>fmeprocessmonitorengine.log) you should see something about an engine ending unexpectedly.
and also you might be able to see multiple versions of the same log in the logs>engine>current>jobs folder. Multiple job logs will be saved in a folder. Here's an example where a job crashed (in this case from memory/space issues) and was resubmitted twice.
itsmatt
Forum|alt.badge.img+48
  • Nov 15, 2023 1:47 PM UTC
mathiku
  • Nov 15, 2023 2:32 PM UTC
Thanks a lot, in this case this would make sense.
Edit: That seems to be the case. The logs look just like your picture.
What could be the cause? Lack of memory?
Event viewer doesn't add much information.
timatsafe
  • Nov 16, 2023 8:21 PM UTC
Hi @mathiku​,
If you could submit a support case with your logs attached here we'd be happy to help you out!
Here's some info on How to Create a Great FME Flow Support Case
Cheers,
Tim
