FME Server can't open Oracle client libraries but Desktop can
  • Mar 23, 2023 7:57 PM UTC
  • 373 views
jonvelco
Forum|alt.badge.img+7
On the FME Server VM I have setup, the 64 bit Oracle Instant Client isn't being recognized by FME Server. I have the PATH environmental variable set to the folder. I also installed Desktop on the same VM and it has no problem connecting to Oracle databases.
What else can I try?
This is the error I get when running the workbench in Server:
Oracle client libraries (e.g. oci.dll) could not be loaded. Ensure that the 64-bit client is installed and properly configured, and the PATH environment variable includes the file path to your Oracle client. Refer to https://community.safe.com/s/article/how-to-setup-an-oracle-instant-client-for-use-with for more information
The Oracle Instant Client setup is the "Basic Package" Version 21.9.0.0.0
FME Server
  • 2022.2.4 Build 22792 - win64
FME Desktop
  • 2022.2.4.0 (20230303 - Build 22792 - WIN64)
  • Database Edition
Best answer by jonvelco
Hello,
Please ensure that this article was used to install instant client- https://community.safe.com/s/article/how-to-setup-an-oracle-instant-client-for-use-with .
This might be a great troubleshooting article - https://knowledge.safe.com/articles/28996/fme-and-oracle-troubleshooting-guide.html
The FMEReport.html after running the system_information.bat file from: https://knowledge.safe.com/articles/714/general-troubleshooting-gathering-system-informati.html should provide additional information including PATH.
@Merline George​ I was able to resolve this with the help of @steveatsafe​ where he noticed I had set the Environment Variable under the User variables instead of the System variables. After I set the PATH System variable, restarted the FME Server services, everything worked. Hope this helps someone else and maybe the article needs to be updated to include this specific.
merlinegeorge
Hello,
jonvelco
  • Mar 24, 2023 6:51 PM UTC
Hello,
Yes - I followed the steps when setting up. FME Desktop doesn't have an issue connecting to Oracle (i.e the reader/writers aren't grayed out and I can run the workbench without issue). FME Server is the issue where it can't find the libraries.
I ran the FMEReport.html as you suggested and I think everything looks ok...image
I've also submitted a case for this (C689290).
jonvelco
  • Mar 31, 2023 1:59 PM UTC
Hello,
