FME Server App not rendering correctly in Edge.
  • Nov 3, 2022 4:39 PM UTC
  • 49 views
btl
Forum|alt.badge.img+12
I've got a server app that uses an HTMLReportGenerator to create a simple web page. It contains a few paragraphs, a table and a very simple SVG chart. However, when I run it from Edge, the SVG is missing, and line spacing and font sizes are different. In Chrome it's fine.
However, if I do View Source, copy the html into a new doc and open that in Edge it looks as expected.
Styling is within the html, except that which it references from bootstrap@4.5.3/dist/css/bootstrap.min.css
siennaatsafe
Hi @btl​ ,
Would you mind sending in the HTML that your app is producing? I'd be interested in taking a look. Could you also let me know what version of FME Server you are using?
