FME Server App - Cache issue
  • Feb 16, 2023 9:21 AM UTC
  • 255 views
lau
Forum|alt.badge.img+3
Hello,
I am facing a cache issue with Autocad file using Workspace App - FME 2022.2.0.0. Build 22765
1. I created and published a workspace that reads a DWG file
2. I created a Workspace App.
3. I upload an Autocad file to my app and runs the workspace. -> OK
4. I make some modification on the DWG file on my machine and save edits
5. I re-upload the Autocad file to my app and runs the workspace -> NOK. The workspace runs with the non edited Autocad file...
6. I go to the App interface and click CTRL + SHIFT + R in order to clear the cache.
7. I upload the edited Autocad file and runs the workspace -> OK, the workspace reads the edited Autocad file.
Is there another workaround I can use instead of clearing the cache ? I don't want my users to rename their Autocad file after edition.imageThe workspace is in attachment.
Thank you !
Laurent
wisegis
Forum|alt.badge.img+17
  • Feb 21, 2023 7:55 PM UTC
I looked at your TestCache file. I would try to turn off the Feature Caching in Workbench and republish the workbench file. It's worth a try.
lau
  • Mar 17, 2023 8:21 AM UTC
Thank you for your suggestion. It doesn't change anything.
@Mark Stoakes​ : is it a known issue ?
keziaatsafe
Forum|alt.badge.img+8
Hi @lau​ ,
When uploading the file and selecting the "Browse Resource" or "Upload" button, can the end-user check the Temporary Uploads tab and ensure the old file is deleted before uploading the updated file? Does this change the behavior?
DeleteTempUploadThanks,
Kezia
