FME Desktop 2022: The sequence of records numbering before and after aggregating don’t match,
  • Mar 11, 2022 9:40 AM UTC
  • 97 views
jamal
Forum|alt.badge.img+5
In the screenshot below, the symbols are numbered and it appears that the numbers start from top to bottom.
As the features are aggregated and re-numbered, it appears that there is no logic based on what they are numbered
Then based on what "counter" tool work?
The data and workbench are attached
Clip_239
Clip_240
Clip_241
mark2atsafe
Forum|alt.badge.img+59
I think this is one scenario where we wouldn't guarantee the same order, except in certain cases. You have the same number of features going in and coming out, so you could set Group By Mode to "Process When Group Changes" and that would give you the same input and output.
But that would not usually be the case. Most people are aggregating multiple features and not in a specific order. So that's why the default is to not worry about the order.
So, as long as you are aggregating data that's already in group order, you can change that parameter and get what you need.
jamal
  • Mar 12, 2022 12:52 PM UTC
Is it possible to number based on the y-coordinates value (descending) such that the highest y-coordinate takes number 1 and so forth?
Clip_254
Forum|alt.badge.img+63
Clip_254
Yes, you can use a Sorter to sort on that attribute and then a Counter.
jamal
  • Mar 12, 2022 7:53 PM UTC
Thank you for the help
