FME Desktop 2020: How to map excel table using “schema mapper”?
  • Nov 12, 2021 10:41 AM UTC
  • 156 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to link the attribute table of a layer with an excel table.
In the screenshot below, I wanted to link the attribute layer with an excel table based on the autocad_color and ColorNo fields in order to get the “type” field values transferred to the layer.
How could be performed?
The data is attached
Clip_1103
muzhnasto
Forum|alt.badge.img+12
  • Nov 12, 2021 5:22 PM UTC
Hi @jamal​ , use FeatureMerger, I think it will help you
jamal
  • Nov 16, 2021 8:32 PM UTC
I got a help from a colleague. Quite easy! All what I need is to add two more fields to the excel table and then to configure the schema mapper correctly as per the screenshot below
Clip_1138
Clip_1139
jamal
  • Nov 16, 2021 8:33 PM UTC
The data is attached with correct configuration
