FME Challenge: Transformer Naming Part II
  • Jul 6, 2017 10:39 PM UTC
  • 57 replies
  • 479 views
Show first post
  • Jul 8, 2017 6:51 AM UTC
An experiment for XML lovers :-) This workspace extracts required transformer names and 3-letter codes from the transformers list (txt) using XQuery expressions, and then outputs the result as an HTML table.
[Updated] unique-3-letter-code-to-html-3.fmwt (FME 2017.0)
You can specify the number of characters per a code via a published user parameter named N.
(: XMLTemplater ROOT Template Expression :)let $s := <s>{fme:process-features("SUB")}</s>let $t := <t>{    for $code in fn:distinct-values({for $x in $s/xformer return $x/@code})    let $names := {for $x in $s/xformer[@code=$code] return $x/@name}    where fn:count($names) eq 1    return <xformer name="{$names[1]}" code="{$code}" />}</t>return <table>    <thead>        <th>No.</th><th>Transformer</th><th>Unique $(N)-Letter Codes</th><th>Count</th>    </thead>    <tbody>{        for $name at $i in fn:distinct-values({for $x in $t/xformer return $x/@name})        let $codes := {for $x in $t/xformer[@name=$name] return $x/@code}        return <tr>            <td>{$i}</td>            <td>{$name}</td>            <td>{fn:string-join($codes, ",")}</td>            <td>{fn:count($codes)}</td>        </tr>        }        <tr>            <td/>            <td/>            <td>Total Number of Unique $(N)-Letter Codes</td>            <td>{fn:count($t/xformer)}</td>        </tr>    </tbody></table>
(: XMLTemplater SUB Template Expression :)let $n := $(N)for $code in fn:distinct-values({    let $src := fn:upper-case(fme:get-attribute("text_line_data"))    for $i in (1 to fn:string-length($src) - $n + 1)    return fn:substring($src, $i, $n),    let $src := fn:replace(fme:get-attribute("text_line_data"), "[a-z]", "")    for $i in (1 to fn:string-length($src) - $n + 1)    return fn:substring($src, $i, $n)})return <xformer name="{fme:get-attribute("text_line_data")}" code="{$code}"/>
  • Jul 8, 2017 12:45 PM UTC
I created a custom transformer to do that: [2017-07-08 Update: Please see the latest comment]
I updated the custom transformers so that digits [0-9] will be considered as Camel-Case characters.
If you have installed the previous custom transformers (ThreeLetterEnumerator, NLetterEntryEnumerator), once delete them from Transformer Gallery, then open this template that contains new implementations.
fme-challenge-transformer-naming-part-ii.fmwt
fmelizard
Forum|alt.badge.img+22
  • Jul 8, 2017 7:52 PM UTC
I am in awe of all of you. Very very impressive.
stalknecht
  • Jul 9, 2017 3:30 PM UTC
If you allow numbers and also the AutodeskA360Connector trick: 743 codes for 316 unique transformers
challenge3chars.fmwt
Without the AutodeskA360Connector trick :738 codes for 316 unique transformers
challenge3charsii.fmwt
If it's only allowed to have letters: 720 codes for 309 unique transformers
challengeonlyletters.fmwt
All workspaces contain 10 transformers.
mark2atsafe
Forum|alt.badge.img+59
  • Jul 10, 2017 6:13 PM UTC
So a late Saturday evening revision because I just couldn't let it go! I re-read some of the comments and realised I wasn't accounting for numeric values in the unique values. But I had read the following:
"The challenge is to scan that list and generate as many unique three-letter codes as you can."
Letters not number otherwise it might have said characters ;)
So my revised new total is 735 unique values containing a mix of numbers and letters, for 316 Transformers @Mark2AtSafe
Good point. I guess I wasn't thinking about numbers when I wrote the challenge. But yes, it should say unique characters.
mark2atsafe
  • Jul 14, 2017 9:54 PM UTC
This is awesome work everyone. I will check out the results and award prizes when I'm back from vacation in a couple of weeks.
  • Jul 15, 2017 1:22 AM UTC
Looks like no one has suggested this approach to enumerate N-characters codes.
[Correction] I missed that this approach has been suggested by @egomm already.
  1. Create N copies of the source string.
  2. Remove leading (N-1) characters from Nth string.
  3. Extract every N-characters substring with the StringSearcher.
fme-challenge-transformer-naming-part-ii-2.fmwt
Something extra:
