FME 2018.0 getting error trying to access or create database connections
  • May 29, 2018 6:12 PM UTC
  • 138 views
jakethepainter
Forum|alt.badge.img+7
Anyone else having this issue?
I open FME 2018.0 18295 32-bit and my stored database connections can't be loaded. When I open the FME Options/Database Connections, I get: "Error Retrieving Connections". The Translation log window is also missing. When I reopen it, I get the below error.
The Java Virtual Machine could not be started. CLASSPATH = '-Djava.class.path=C:\\apps\\FME2018\\common-webservices.jar;C:\\apps\\FME2018\\plugins;C:\\apps\\FME2018\\plugins\\activemq-all-5.6.0.jar;C:\\apps\\FME2018\\plugins\\amazon-kinesis-client-1.6.1.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-cloudwatch-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-core-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-dynamodb-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-kinesis-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-kms-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-s3-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-sns-1.10.77.jar;C:\\apps\\FME2018\\plugins\\aws-java-sdk-sqs-1.10.77.jar;C:\\apps\\FME2018\\plugins\\bcpkix-jdk15on-1.55.jar;C:\\apps\\FME2018\\plugins\\bcprov-jdk15on-1.55.jar;C:\\apps\\FME2018\\plugins\\common-util-api.jar;C:\\apps\\FME2018\\plugins\\common-util.jar;C:\\apps\\FME2018\\plugins\\commons-codec-1.9.jar;C:\\apps\\FME2018\\plugins\\commons-io-1.3.2.jar;C:\\apps\\FME2018\\plugins\\commons-lang-2.6.jar;C:\\apps\\FME2018\\plugins\\commons-logging-1.2.jar;C:\\apps\\FME2018\\plugins\\dmtilhplugin.jar;C:\\apps\\FME2018\\plugins\\dom4j-1.6.1.jar;C:\\apps\\FME2018\\plugins\\dropbox-core-sdk-2.1.1.jar;C:\\apps\\FME2018\\plugins\\dropboxfactory.jar;C:\\apps\\FME2018\\plugins\\dynamodb.jar;C:\\apps\\FME2018\\plugins\\fmedesktopshared.jar;C:\\apps\\FME2018\\plugins\\fmeserver-api.jar;C:\\apps\\FME2018\\plugins\\fmeserverconfiguration.jar;C:\\apps\\FME2018\\plugins\\fme_jdbc.jar;C:\\apps\\FME2018\\plugins\\gcmfactory.jar;C:\\apps\\FME2018\\plugins\\google-api-client-1.21.0.jar;C:\\apps\\FME2018\\plugins\\google-api-services-bigquery-v2-rev260-1.21.0.jar;C:\\apps\\FME2018\\plugins\\google-http-client-1.21.0.jar;C:\\apps\\FME2018\\plugins\\google-http-client-jackson-1.21.0.jar;C:\\apps\\FME2018\\plugins\\google-oauth-client-1.21.0.jar;C:\\apps\\FME2018\\plugins\\googlebigquery.jar;C:\\apps\\FME2018\\plugins\\guava-18.0.jar;C:\\apps\\FME2018\\plugins\\hsqldb.jar;C:\\apps\\FME2018\\plugins\\httpclient-4.4.1.jar;C:\\apps\\FME2018\\plugins\\httpcore-4.4.1.jar;C:\\apps\\FME2018\\plugins\\iijdbc.jar;C:\\apps\\FME2018\\plugins\\ili2c.jar;C:\\apps\\FME2018\\plugins\\ili2fme.jar;C:\\apps\\FME2018\\plugins\\ingres.jar;C:\\apps\\FME2018\\plugins\\jackcess-2.1.7.jar;C:\\apps\\FME2018\\plugins\\jackcess-encrypt-2.1.1.jar;C:\\apps\\FME2018\\plugins\\jackson-annotations-2.5.3.jar;C:\\apps\\FME2018\\plugins\\jackson-core-2.5.3.jar;C:\\apps\\FME2018\\plugins\\jackson-core-asl-1.9.12.jar;C:\\apps\\FME2018\\plugins\\jackson-databind-2.5.3.jar;C:\\apps\\FME2018\\plugins\\jackson-dataformat-cbor-2.5.3.jar;C:\\apps\\FME2018\\plugins\\jackson-mapper-asl-1.9.12.jar;C:\\apps\\FME2018\\plugins\\jaxen-1.1.1.jar;C:\\apps\\FME2018\\plugins\\jdbcLdap.jar;C:\\apps\\FME2018\\plugins\\jmsfactory.jar;C:\\apps\\FME2018\\plugins\\joda-time-2.9.jar;C:\\apps\\FME2018\\plugins\\json-20140107.jar;C:\\apps\\FME2018\\plugins\\jts-core-1.14.0.jar;C:\\apps\\FME2018\\plugins\\kinesisfactory.jar;C:\\apps\\FME2018\\plugins\\ldap.jar;C:\\apps\\FME2018\\plugins\\log4j-1.2.16.jar;C:\\apps\\FME2018\\plugins\\netty-3.6.3.Final.jar;C:\\apps\\FME2018\\plugins\\ojdbc7.jar;C:\\apps\\FME2018\\plugins\\pluginbuilder.jar;C:\\apps\\FME2018\\plugins\\postgresql-9.3-1102.jdbc41.jar;C:\\apps\\FME2018\\plugins\\protobuf-java-2.4.1.jar;C:\\apps\\FME2018\\plugins\\s3factory.jar;C:\\apps\\FME2018\\plugins\\server-configuration-common.jar;C:\\apps\\FME2018\\plugins\\server-internal-api.jar;C:\\apps\\FME2018\\plugins\\server-plugin-common.jar;C:\\apps\\FME2018\\plugins\\snsfactory.jar;C:\\apps\\FME2018\\plugins\\spanner-jdbc-0.20.jar;C:\\apps\\FME2018\\plugins\\sqljdbc41.jar;C:\\apps\\FME2018\\plugins\\sqsfactory.jar;C:\\apps\\FME2018\\plugins\\teradata_jdbc.jar;C:\\apps\\FME2018\\plugins\\tfs.jar;C:\\apps\\FME2018\\plugins\\ucanaccess-4.0.2.jar;C:\\apps\\FME2018\\plugins\\websocketfactory.jar;\\\\c01u10\\c01u10\\eej2013\\My Documents\\FME\\Plugins\\Java'. Return code is '-1'
JVM Message: Error occurred during initialization of VM
JVM Message: Could not reserve enough space for 262144KB object heap
If I restart my computer, I can open FME and the database connections are back. I can't break it just by opening/closing/running a workbench, but at some point I go to open a workbench and I get the error again. Haven't dialed in the repro steps, but I can't go a day without it happening.
2017 is working great on the same machine. Have the problem on a different machine as well.
Best answer by andreaatsafe
Hi @jakethepainter,
I'm sorry to hear that you've encountered this problem!
Are you opening a workspace via the context menu (right-click a workspace > open with FME Workbench)?
If so, could you launch FME Workbench first, and then open the workspace? Does the error message still occur?
From what you have described, this sounds similar to a known issue on 32-bit that has been fixed in FME 2018.1 beta. Could you try the latest beta version found here or upgrade to FME 64-bit found here.
If you are still encountering a similar error after launching FME Workbench first or trying FME 2018.1 beta, please report a problem here.
andreaatsafe
Forum|alt.badge.img+17
  • May 29, 2018 9:49 PM UTC
Hi @jakethepainter,
jakethepainter
Yes, that does seem to work to open 2018.0 first and then open the workbench. Good to know.
I'm having trouble downloading the beta; it may not be whitelisted for me.
jakethepainter
Just wanted to report that the beta did indeed fix the issue for me.
andreaatsafe
Thanks for letting us know @jakethepainter ! :)
