Find the Count of Overlapping/Valance nodes in a Polyline file
  • Nov 2, 2015 10:41 AM UTC
  • 8 replies
  • 143 views
parashari
Since, I work with spatial data and more into ESRI formats, so I come along with different problems with the same format type, and again, I am stuck with a new problem here. Though, its a bit difficult to explain, yet, let me try:
I have a Road Network with Polyline geometry. Each Road Network Element (line segment) has a start and an end node. If we split the line at junctions/intersections and add a point to each start an end node to each Line Segment, there will be a certain number of overlapping nodes (image below).
My question is will I be able to extract the count of nodes at every junction?
Pl feel free to ask queries if I am not able to communicate properly.
sigtill
Forum|alt.badge.img+25
  • Nov 2, 2015 10:56 AM UTC
Use a SpatialRelator with the same data as Requestor and Supplier. You will then get a _related_candidates with the number of overlapping nodes
sigtill
  • Nov 2, 2015 10:57 AM UTC
@hellblazer
  • Nov 2, 2015 11:23 AM UTC
Hi
Take a look at the TopologyBuilder. Using the output lines, count the number of uniquely occurring values in from_node and to_node, this count will give you the number of connections for each node ID.
David
Forum|alt.badge.img+54
  • Nov 2, 2015 3:44 PM UTC
You could also use a matcher to find overlapping nodes, outputting via the singlematched output port and setting the "match count attribute on singlematched output" will give you a count of nodes at each location.
parashari
  • Nov 3, 2015 11:08 AM UTC
Thanks everyone for the advices and help!! :)
@sigtill Though, i did try your method, but I guess I was making a very minute mistake somewhere. I tried using Intersector (for generating nodes out of lines) and SpatialRelator (to obtain the Valance counts in _related_candidates).
@david_r I did try TopologyBuilder and found all my _from_node and _to_node unique. I am not sure how I can move ahead with this.
@egomm I tried using Matcher but didn't find the solution. Can you explain a biy more
Apart from this, I tried using Intersector (to get the nodes and to split the line at junctions) and PointOnLineOverlay. Under the _overlap, I got the desired result. Yet, it is under testing.
  • Nov 3, 2015 12:10 PM UTC
Use a LineOnLine overlayer to split lines into segments where they meet/cross other lines, create points at start and end points of the resulting line output, then the matcher to count how many points are in the same location
  • Nov 3, 2015 12:26 PM UTC
Hi
Using the TopologyBuilder works for me. I could even simplify it a bit using only the output nodes and then counting the elements in the _node_angle{} list:
Here's the relevant part of the workspace:
David
gio
Forum|alt.badge.img+15
  • Nov 3, 2015 4:06 PM UTC
-Topology builder, ie. like David shows.
-Network to create from to's. Compare etc. like below.
-Or old style: vertex-extraction (start and end)
Listbuilder grouped by line_id.
Then unconditional merger.
Then compare end_node to start_node. (x,y comparison). Count em.
Wichever you use, it involves list-functions.
