Fanout output directory setup
  • February 17, 2022
  • 28 views
mustafa.salah
Hello
I 'm trying to have the Fanout output directory stamped by date, I successfully did that except FME creates 2 folders of same content except one with the date stamp and the other without. Both directories are identical from inside, any advice?
I'm using the parquet writer to export Revit elements properties to parquet files, here is my settings for output directory.
Fanout output directory settingsThe output comes as following:
Fanout output directory resultWhat I was expecting is the folder with date only???
The same other folder "rst_basic_sample_project" with all its content is replicated in "2022-02-17"
I only want "2022-02-17"
Forum|alt.badge.img+50
Is all of the content in the folder with the timestamp replicated in the one without the timestamp?
mustafa.salah
yes
Fanout output comparisonFrom the figure you can see this clearly.
mark2atsafe
Forum|alt.badge.img+48
  • February 18, 2022
You do seem to have two Parquet writers. Is this intentional?
mustafa.salah
Yes, but it turned out the issue was coming from something else. I connected the starter and the dates tamper to the writer node, which has been considered as two different data streams so that is why the duplication happened.
The problem has been solved by connecting the starter to the date stamper then the date stamper to the writer.
