Excel Writer: Failed to refresh Pivot Tables and recalculate formulas.
We recently downloaded the 2021.1 version of FME. All previous scripts run on 2020.1 without problems. Now however, I get a warning message "Excel Writer: Failed to refresh Pivot Tables and recalculate formulas. Note this is only possible on Windows with Excel installed" when exporting to an excel with the use of a template. I write my data in 1 tab, and that tab is used to make a pivot table in another tab. Because of this warning, the excels in my dataflow I have stay open and after 20-ish files the memory in my task manager is full, so the translation fails. We did not change the version of Excel, that should not be the problem.
Anyone an idea what could be the problem?
daraghatsafe
Hi @ega​ this sounds like it could be a bug. I have escalated your post to a case. Hopefully, we can find a solution to his soon. I will contact you through the case.
fgiron
Forum|alt.badge.img+21
  • June 1, 2022
Hi @daraghatsafe​, I've just run into this same issue in FME 2022.0 (b22339). Has it been confirmed it is a bug? Do you maybe have any updates?
spatialcase
  • April 18, 2023
Hi, This is still an issue in 2022.2.1
  • April 21, 2023
Hi, I had this issue and for me a workaround was to deselect the option to 'refresh data when opening the file' in the Excel file I use as a template (using FME 2021.2.5.0).
  • April 24, 2023
Hi jooms, did it also work on FME Server while testing it or locally on your device? Thanks
  • April 25, 2023
I don't use FME Server so I haven't tested this. Only with FME Desktop.
  • May 8, 2023
Locally it does work with the option enabled and disabled. However, it is not working on FME Server yet. 'Unable to recalculate formulas and refresh pivot tables for Excel file 'Failed to open workbook. Ensure this is a valid Excel file'. @jooms​
If I find a solution, I'll update the post
I am encountering this same issue with FME Flow 2023.0.2.1Build 23339 - win64, can we have someone from Safe confirm if this is still an issue?
kate-safe
Forum|alt.badge.img+10
  • February 12, 2024
Hi @bradpainter,
It looks like our team resolved this issue in 2023.2 and higher!
If you are able to update, you should see that fix and have no further issues!
mgauffeny
Participant
  • Participant
  • June 25, 2024
I’m sorry but with 2023.2 it’s not working too…..
Do you know why?
Thanks!!
Marc
