Error while validate wms in fme inspector
  • Oct 24, 2019 4:08 PM UTC
  • 38 views
Hi, I am not very familiar with fme. I want to serve tiff image through WMS by using FME Server. But i get this error when I want to validate the output by using fme inspector. I'm using the fme server 2019.1 and tested the output by using fme inspector 2013. Can someone explain me why this error occurred and how to solve it? Here also I attached the fmw file that I used which been downloaded from this fme community and the error that I get. Thank you in advance
  • Oct 25, 2019 3:24 AM UTC
I've run the tiff-to-wms.fmw by using fme 2019.1 and the translation is successful. But, getting error while I want to validate this by using the fme inspector 2013. Any advice will be greatly appreciated. Thanks you
sigtill
Forum|alt.badge.img+25
  • Oct 25, 2019 6:15 AM UTC
Do you have FME Server on HTTP or HTTPS ? Might be just missing https:// instead of http:/ in the URL?
itay
Forum|alt.badge.img+19
  • Oct 25, 2019 9:20 AM UTC
By inspector are you referring to the Data inspector application or the transformer?
