Error when trying to overwrite an existing ArcGIS Portal feature
  • September 4, 2020
  • 9 replies
  • 501 views
Hi all,
I have a workbench which takes a CSV, creates vertex's and then publishes to ArcGIS Portal. This works fine and I can view the data in Portal, but it fails if I try to run the workbench again to overwrite the feature... which is something I need to do every morning.
I get this error:
ArcGIS Portal Feature Service Writer: 'addResults' error for a feature in 'COVID_Joined_Tables'. The error code from the server was '10500' and the message was: 'Cannot convert a value of type 'java.lang.Double' to 'SMALLINT'.'
I have the Portal writer set to INSERT and to Truncate first YES, which I think is the right setting to be using?
I guess it is something to do with Portal converting a field type when it get's created, and it finds a mismatch when trying to overwrite it.
I have checked the attributes of the fields and only one field is down as SmallInteger, so I tried changing that thinking that may have been the field causing the problem, but no luck. I have attached a picture of this and also the overall workbench.
Any ideas please?
Thanks, Dan
  • September 4, 2020
@dan_mbc​  are you able to include a small sample of the data and your workspace? Also, did you use FME to create the Feature Class on your Portal, the first time you loaded the data? (if you can't make the data public you could send it to me at mark @ safe.com)
  • September 7, 2020
Thanks for the response @Mark Stoakes​ . Sorry I didn't see this over the weekend!
I have attached a sample of data which has been anonymised. This is the CSV which is then used to create the feature class in Portal. So yes this feature is used to create the feature in Portal as a new feature.
I don't think I can share the workspace as that has the live data in it which is sensitive. If you need me to send anything else please let me know.
Thanks again.
f.kemminje
Forum|alt.badge.img+11
  • September 8, 2020
Hi @dan_mbc​ Try to check the value in your csv file. may be the first time when you write , the value is small, Next, you are truncating the table, but the column definition is set to the old values(old fme run)that came in. you can create table every time, instead truncating.
  • September 8, 2020
Thank you for the suggestion.
The values arent changing at this stage, as I was just checking the workbench works. It works when creating it, but not when trying to update it/overwrite it. So I don't think it is a value size problem.
I could try just creating it everytime, but wont this mean a new version of the data everytime? And I will have to delete to previous version? The reason I was trying to overwrite is because I have the feature layer in maps and setup with symbology etc., so I am not sure if recreating it will break that link.
trentatsafe
  • September 29, 2020
Thanks again.
Hi @dan_mbc​
I think the issue is tied to the JSON being sent to the Feature Service, when the Feature Service already exists. If you are able to cast the integers, using an AttributeManager as follows, I think it should work.
For example:
northings = @Evaluate(@int64(@Value(northings)))
eastings = @Evaluate(@int64(@Value(eastings)))
age = @Evaluate(@int8(@Value(age)))
Let me know if that works!
  • September 30, 2020
Thanks again.
AttributeManagerHi @trentatsafe​ , thank you for the suggestion.
I have just tried this, and I don't think it is working or I have configured AttributeManager incorrectly (probably the latter!). I have tried the attached settings.
But it seems to rename the actual attributes, as shown in the snippet above, which then in turns makes the next step which creates the vertex fail. Have I just got the values wrong? I used the Attribute Manager after the AttributeRenamer and before the vertex creator. It runs through AttribureManager fine, but then obviously fails in the vertex creator due to the fields now looking like easting = 447758 etc.
Thanks
Thanks again.
I have just updated the AttributeManager and think I now have it configured correctly, screenshot attached.
The error when trying to run for second time/overwrite is:
ArcGIS Portal Feature Service Writer: Encountered an unexpected error. The error code from the server was '500' and the message was: 'JSONObject["globalId"] not found.'. Details: ''
ARCGISPORTALFEATURES writer: A fatal error has occurred. Check the logfile above for details
... Last line repeated 2 times ...
Thanks
DanAttributeManager1
  • October 5, 2020
Thanks again.
@dan_mbc​ It looks like your entering the functions as literal strings. In the AttributeManager, use the Arithmetic Editor to build the expression from the Math Functions:
 2020-10-05_11-54-06
david.van.dalen
Forum|alt.badge.img+7
Hi @dan_mbc​ and others coming across this error,
In my case it turned out to be a string-value exceeding the size of the esriFieldTypeString(width) attribute in the Feature Type definition. The first run writing to a new feature service gives no problem. The second run writing the same data to the exisiting feature service throws this error.
