Error when creating a database connection
  • Apr 20, 2023 1:42 PM UTC
  • 328 views
Hello,
I am using FME Server 2021.2.3 deployed on couple of machines in a fault tolerant configuration
We have an Oracle database 19c. I have tried to connect to the database in FME Server, but getting the error message below (see attached also). I can connect to the database from SQLDeveloper on the same server.
A similar issue was reported in https://community.safe.com/s/question/0D54Q000080heRDSAY/not-able-to-create-a-new-database-connection-on-fme-server
However the solution needed a reinstall of FME Server.
Does anyone have other suggestions ?
929028:SQL Query SELECT NCID FROM fme_nc_namedconnections WHERE connectionname = ? AND username IS NULL failed. Error: Unsupported feature
keziaatsafe
Forum|alt.badge.img+8
HI @ravinhasseea​ ,
In your install configuration, did you use your own ojdbc or the default one used by FME?
Are you able to connect to the database successfully from FME Form (Desktop)?
Does creating this database connection in FME Workbench and publishing it to FME Flow (Server) fail too?
Kezia
HI @ravinhasseea​ ,
Kezia
Thank you for the response @keziaatsafe​
We did manage to fix this by updating from ojdbc6 to ojdbc8
