Error message when converting four shapefiles into one FGDB.
  • Jan 12, 2022 1:40 PM UTC
  • 89 views
arash_hokm
Forum|alt.badge.img+8
Error message when converting four shapefiles into one FGDB. Error consists of:
An error occurred while attempting to create the feature class 'SB_Aussenkasten'. The error number from ArcObjects is: '-2147220649'. The error message from ArcObjects is: {Cannot create double column table.}
CraeteFGDBI would be thankful. if someone could tell me what the problem is.
Thanks very much.
Best answer by nielsgerrits
The source (SB_Aussenkasten) apparently has the attributes "BAUTEILNUM" and "Bauteilnum".
This can happen if you have multiple shapes with the same names in different folders.
In a GDB featureclass columns are not case sensitive and this is not allowed as these are seen as the same. So you need to fix that or rename one of them before writing to gdb.
You can do this using an AttributeRenamer, rename "BAUTEILNUM" to "Bauteilnum".
If you have a lot of columns you also can use a BulkAttributeRenamer to change all columns to lowercase.
nielsgerrits
Forum|alt.badge.img+67
  • Jan 12, 2022 1:58 PM UTC
arash_hokm
  • Jan 12, 2022 2:18 PM UTC
@nielsgerrits​ Many thanks for your help. I also have other question about creating relationship between Excel spreadsheet and FeatureClass in an FGDB. i will ask in other post.
