Dynamically Read Multiple CSV Schema - Organize - Export as Standard CSV Structure
  • Mar 28, 2022 4:57 PM UTC
  • 297 views
canerakin
Goal:
I am trying to standardize the raw CSV files. The output file columns should look like below.
Date	Time	Level	Temperature	Elevation
Background Info:
Each file might have multiple tabs. I need to only process the sheets that named as 20* (2011-2012-2019-2020 etc). Sometimes there is header information in A column in some of the sheets. Thus the table header starts at different row number.
Issue:
I am using FeatureReader to detect the schema dynamically. If the table starts with header information, the transformer reads the data as a new table. Thus it creates new column names which turns into a larger issue.
Normally there are over 200 files with multiple tabs but I've prepared a sample data and included my workbench. Looking for help.
Best answer by nielsgerrits
For this reason I prefer to use the Generic Reader to dynamically read Excel files. Then you get col_1, col_2, etc... which you can rename yourself. Attached sample with your data.
nielsgerrits
Forum|alt.badge.img+67
  • Mar 29, 2022 10:17 AM UTC
canerakin
  • Mar 29, 2022 1:34 PM UTC
Hi @nielsgerrits​ , I tried so many things but never thought about Generic reader. It definitely gave me a better direction, thanks a lot!
nielsgerrits
Happy I could help. :)
