Dynamic vector tolerance value transformer Matcher
  • Nov 24, 2023 9:08 AM UTC
  • 87 views
jsmitsman
I want to set the vector tolerance value in the Matcher with a dynamic value.
Currently, I can use a parameter value only. Is it possible to use an attribute value for this, or how can I set this value more dynamically?
I have been trying also to create a custom transformer with the matcher in it. However, I got the same issue.
  • Nov 24, 2023 10:30 AM UTC
Hi @jsmitsman​ ,
I think there is no way to set the tolerance value dynamically since it should be applied to all the input features equally, as long as you do it within a single workspace.
If you run the workspace through a WorkspaceRunner in another workspace, you can set the parameter for each run, but I don't know it's the case for your requirement.
nielsgerrits
Forum|alt.badge.img+67
Hi @jsmitsman​ ,
This is how I solved a similar issue, but moving data between workspaces can be a bit of a hassle. One way to solve this is with Recorder and Player transformers, but I'm not sure if that works as well on server.
