Dynamic Sampler
  • Apr 18, 2022 2:31 PM UTC
  • 124 views
boubcher
Forum|alt.badge.img+11
Hello guys we have a GDB with multiple layers, we need to generate sample data for each layer but with different rates for each layer, the problem I have is the sampler transformer will take only user parameter value not an attribute value
how could we set the rate based on the attribute value ??
Thanks
danilo_fme
Forum|alt.badge.img+58
  • Apr 18, 2022 3:25 PM UTC
Hi @boubcher​
Did you try to extract your GDB using the transformer FeatureReader?
There is a configuration into this transformer Max Features to Read - and you can use a attribute value.
FeatureReader
Thanks in Advance,
Danilo
boubcher
  • Apr 18, 2022 5:54 PM UTC
Hi @boubcher​
FeatureReader
Thanks in Advance,
Danilo
@danilo_fme​  thanks for your response
we can read the GDB, this is not the problem, what we are looking for is to generate a random sample of the data.
the sample rate depends on the feature type name and total features of each features type
the only option there is to use parameters, we do have 50 layers and we don't know the sample size in advance it's calculated based on the total feature by features type
Thanks
Sample Rate
dustin
Forum|alt.badge.img+36
  • Apr 18, 2022 7:29 PM UTC
Have a look at this thread. I believe it may be of some help.
Sampling rate from attribute value (safe.com)
boubcher
  • Apr 28, 2022 2:53 PM UTC
@dustin​
Thanks so much for the info, its working
