Dynamic listing of parameter names
  • Jul 31, 2023 2:42 PM UTC
  • 97 views
dustin
Forum|alt.badge.img+36
One thing I prefer to do when building a new FME tool is to log the input parameters in a startup python script in order to facilitate debugging when things go wrong. A sample of the code I use is below.
import fmeobjects
fmeobjects.FMELogFile().logMessageString("Input parameter 1: ") + FME_MacroValues["parameter1"], fmeobjects.FME_INFORM)
fmeobjects.FMELogFile().logMessageString("Input parameter 2: ") + FME_MacroValues["parameter2"], fmeobjects.FME_INFORM)
This has worked great for a long time, however it's cumbersome because I need to manually enter the names of the parameters. I'm curious if there is a method for returning the names of parameters dynamically in the startup python script, and then loop through them to include in the log file. If this is possible, I could keep my startup script the same between all tools and simply copy it into new tools without having to modify.
Best answer by saraatsafe
Hi @dustin​,
You can try iterating through macrovalues and excluding most of the irrelevant FME-specific values. For example:
import fme, fmeobjects
for k, v in fme.macroValues.items():
    if k.startswith("FME_"):
        continue
    fmeobjects.FMELogFile().logMessageString(f"{k}: {v}")
Hope this helps!
saraatsafe
Forum|alt.badge.img+13
  • Jul 31, 2023 6:41 PM UTC
Hi @dustin​,
        continue
Hope this helps!
dustin
  • Jul 31, 2023 7:29 PM UTC
Hi @dustin​,
        continue
Hope this helps!
@saraatsafe​
Thank you! Brilliant! This is what I came up with:
import fme,fmeobjects
fmeobjects.FMELogFile().logMessageString("---------\n------------------\n---------------------------\n------------------------------------\n", fmeobjects.FME_INFORM)
for k,v in sorted(fme.macroValues.items()):
    if k.startswith("1_"):
fmeobjects.FMELogFile().logMessageString("------------------------------------\n---------------------------\n------------------\n---------\n", fmeobjects.FME_INFORM)
I'll just need to make sure I prefix my  parameter identifiers with "1_". And the result:
