determine which feature with which feature have the same ID
  • Jan 11, 2023 12:23 PM UTC
  • 76 views
arash_hokm
Forum|alt.badge.img+8
Hello FME Community,
I have a shapefile that contains an ID column. the ID must be unique, but I have data records that have come twice.
Only ID is the same and other columns are different.
with DuplicateFilter I filter Duplicate. so I get features that came twice. I would like to know that which feature with which feature have the same ID.
Thanks in advance for your help.
Best answer by redgeographics
Instead of a DuplicateFilter you can use a Matcher, all features that match will be output through its Matched port.
Forum|alt.badge.img+63
arash_hokm
  • Jan 11, 2023 12:39 PM UTC
@Hans van der Maarel​ Thanks alot
srinivasgg
Forum|alt.badge.img+7
  • Jan 11, 2023 3:54 PM UTC
There can be many ways to do this.
Using FeatureJoiner/FeatureMerger - after adding the records data you can get matched data from BOTH shape file and DataRecords.
Using DatabaseJoiner - can join the data records using the column ID.
